Square Eye
- Location
- West Central Texas
First time on the MM board. Thanks for having me. I may be on here a lot with questions.
Here's my problem. I have my FIL's G900, propane, Ser. #33000521. It's been sitting for a number of years. I'm trying to resurrect it. I don't think the engine is locked, but I would like to find out before I throw money at it. I jacked up the right tire, put it in 5th gear & rotated the tire, thinking this would make the engine turn, too. No dice. I can hear the gears moving, but no movement on the engine.
Another thing I discovered is that the Amplitorq lever will not engage or maybe disengage, since I don't know if it's engaged or not. I don't know if this would affect the clutch/motor engagement.
As you see, I've got a lot of "I don't know's" in here. That's why I need your help. Where do I begin to tackle this problem?
I do know the starter is bad. The solenoid is not. I've gone through the wiring, & cleaned and/or replaced all the wiring except the lights. If I determine that the engine is free & can get the clutch operational, then I thought I would try to pull it to start it.
If I reach this level of success, then I'll be willing to spend some money on her.
Any suggestions you have would be welcomed heartily.
