More 1950T help please
who_knos
Hello again fine folks of YT, I am hoping someone can help me out again. I am looking for the part numbers for the sealing ring that goes between the snap ring and low range gear(or is it even needed) , the oring at the end of the shaft that the nut seats to(or will any oring work), the 3 top cover gaskets and the link for the coupling chain. I have a service manual but no parts manual as this isnt my tractor. Any help would be great thanks.
Click this link and go to guest login. In the search box put in 1950, then got to the drop down menu to the right and select White. For some items you may need to look in the "breakdown"
catalog. http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
Why not send me an e-mail and include your snail mail address and I will send you some information. You can also look up parts on line. J.
Well maybe. I just found a bulletin on the assembly of that shaft. Post a U. S. mail address and I will make you copy and send it to you before you need to do it over!
