More 504 hydraulic questions
1st thing, thank you all.I always appreciate your help,Thank You!
I installed my filter cover as suggested, and have drained the milk water fluid from two plugs in the belly and the plug under the rearend I also flushed all lines,valves and couplers,ANY MORE i should drain?pto housing?axle housings?
Which plug do i fill from?i found these two(see pics)
Also before i took i apart the 3 point lift would change positoins by itself.i found this fork broke upon inspection and welded it back, Do i need to adjust anything here after i get it runnig
Thank you!
The plug to the left of your gearshift in your first picture is the fill plug. Remove it with a 3/4 drive ratchet or breaker bar.
The plug on top of the pto housing in your last picture is not a fill plug. It is the access hole for adjusting the brake on the live pro.
I have a 1965 gas 504 utility with a 2001 loader that has served on our farm since new. They are a good tractor if maintained properly and not abused.
