More electrical question - 8N
csulaguy
Do I still need to use the resistor if I switched to an electronic ignition? Regarding the starter, does the top terminal post connect to the starter solenoid switch and then from the other switch post, straight to hot on the battery, since the frame will be connected to ground?
