Dave H (MI)
Same toolbox. Like I said, it came with boxes and buckets of stuff. Top to bottom we have 8 bars about 7 3/4 inches long. 1/4 inch thick and 3/4 wide. Rounded at either end and a hole drilled at either end. They are bolted together using these holes and that is all I know about them. Center is two matching pieces that look a lot like sine bars without the rounded pieces. They are about as close to exact copies of each other as I can determine. No markings. 5 holes of graduated diameter running up the sides. Not threaded. Two items on the bottom are solid brass with gray paint on the bases. The knurled bolt has a steel ball imbedded in the head. Balls rotate in place. The vertical part of base is flattened on three sides and threaded hole is on each of these flattened areas. The center bolt blocks these holes. A great curiosity to me, these items, but mostly these last two. These are roughly 4 inches high and quite heavy.
