More Tear Down Super A
fixmnflym
Thanks for all the Welcomes....glad to be here.The stands were definately improvised, but were rock solid. Railroad tie cribbing in the back, and 2 wide base stands up front. The original idea behind tearing it down this way was to build the engine and re-furbish the front end, put it all back together, then move to the rear. But after getting the engine off, it was clear that this was one worn out machine, so decided to keep tearing down. Seems mice had been living in the bell housing and drive shaft housing for a couple generations. I literally had to take a prybar and poke the mess apart (pic with stuff in pan, 4 of those came out). And the throwout bearing was the old carbon type and had never been changed and was worn clear through the carbon to the metal, ruining the pressure plate in the process of course. For those that asked, the name comes from my work, I'm an aircraft mechanic by trade, been in the airline business over 25 years now. In the old days, us mechanics used to go on "test hops", a check out flight with only a few crew on board. But we don't do too much of that anymore. Like everything else, the bean-counters run everything and they say its not needed. Like I said, I have been reading this site since last August, and I have been following the 4-H tractor, and all the others projects both big and small, for quite a while. Sounds like a nice project for the kids.
the clutch on my a was full of mice houseing also, but ony after i bought a new one to replace it and the tare down. good work. nice machine to have.
about ten years ago I purchased new fingers for my presure plate from my local IH dealer, on mine everything else was ok.
I am not sure if those graphite bearings are still available. I had to replace my carrier with a used one and new bearing when I did mine.
You need to replace those mice when you re-assemble the tractor. Every A, B, C, etc. that I have worked on had them. They were installed at the factory, or soon after.They are supposed to pedal on the clutch fingers to increase the power.
(quoted from post at 18:07:58 03/23/12) You need to replace those mice when you re-assemble the tractor. Every A, B, C, etc. that I have worked on had them. They were installed at the factory, or soon after.They are supposed to pedal on the clutch fingers to increase the power.
Harold is right, I've worked on MANY Farmall Super A's and the other tractors in that family over the years, and currently we have around 57 Farmall Cubs, Super As, 100s, 140s; and they've almost all had the nest in there.
It looks to me like you've got a 1952 Super A. I can tell because for a VERY SHORT peroid (6 months or less), they used that particular tail light/work light combo on them. That is a highly sought after peice in original condition (worth about $150 working, and it should work). Don't let anything happen to it!!
It looks to me like you've got a 1951 Super A. I can tell because for a VERY SHORT peroid (6 months or less), they used that particular tail light/work light combo on them. That is a highly sought after peice in original condition (worth about $150 working, and it should work). Don't let anything happen to it!!
Only one I have available right now is a used one that came out of the heater on my sister's car. It has been stinking all winter, finally got it out.
