Hello,
I tried to follow the tests outlined in replies to my previous post.
I will try my best to summarize what I found.
First, the resistor on top of the distributor is definitely getting voltage from the battery/ignition switch. Also, there is a notable (albeit small) voltage drop across the resistor, which I have heard means the resistor is doing its job.
Then, I used my multimeter to check resistance in the coil. Per the posted instructions, I tested the coils primary winding to be about 1.7 ohms of resistance.
The secondary winding in the coil (the one with the high voltage output to the distributor) tested at about 8500 ohms. From what I read, both of these are good figures.
Next, I tried the test where I put the test light on the distributors small side input, the small wire that comes from the coil and attaches to the side of the distributor. Based on the instructions from a previous post, my test light should flicker when I crank the engine.
However, I ran into a problem doing this test. I am not sure how to slowly crank my engine over. I used the starter to crank the engine, but the test light did not flicker, it only got dimmer when I used the starter. However, I think the starter was cranking the engine too fast for me to even see a flicker with the test light. I do not have a hand crank, so I am not sure how to more slowly crank the engine.
I am also not sure what to test next. The weird thing to me is, the coils secondary winding shows proper resistance (8500 ohms) but yet the high voltage output of the coil will not create a spark when held 1/8 inch from the block.
Any help is greatly appreciated,
John
John
