More unknown frame weights
Dick S
Have a pair of frame weights, part number 371258-R1, and don't know what tractor(s) they fit. Any information will be appreciated. Thanks.
these weights are off my 340, now on the 240.
The frame weights which fit on the Farmall 240 and 340 tractors are different for each side. The left side front bolster one is p/n 371389R1 while the right side one is p/n 371390R1. I have two sets of them and those part no's are cast in the weights and I have one set installed on my Farmall 240 along with the center slab weight p/n 371202R1 which attaches using (4) 3/4" cap screws along with the two threaded holes in the front of those shown on your 240, Hal.
Your 371258R1 weights are front bolster weights (two of the same p/n rquired) for the International 340 Utility tractor and maybe something else (unknown to me) but will not fit on the Farmall 340 model as they are different and use the same front bolster weights as used on the Farmall and International 240 Utility model tractors as I noted previously. Hope this helps if you are looking for a potential use or information to make a sale, Hal.
