Tree-Farmer
Happy Fourth!
Thank you to Roger and Wore Out and everyone who helped with my previous question
I did make the changes to set it to Wide position. I put a bar on my drawbar to connect the center chain.
My current problem is: It won't raise it off the ground and when I lower, the bar isn't flat on the ground.
I would like to ask your help in: How to set up this mower? Or What am I doing wrong?
I'm guessing that the problem is the chain on the back. Since I turned that metal piece over to set it wide, the chain is now farther away, it s like the chain is now shorter.
How do I adjust these 2 chains? What's the correct length? How do I make them be the correct length?
Am I doing something else wrong? Did I do the connection to the drawbar correct?
I did find the manual, but it doesn't seem to cover this.
Thank you to any JD 350 mower experts that can help!
