Mounting a loader on a WD-Help
Keith Molden
I've got an AC loader made by Freeman that I took off a WD last year, sold the tractor. Now I want to put on another WD, but with my poor memory, I can't for the life of me remember where the lines connected. There is a remote control valve for it and it has a trip bucket. Think this old age isn't all it's cracked up to be. Guess I need to take more pictures but would forget where I put the camera LOL. Any help would be greatly appreciated. Thanks and Merry Christmas. Keith
My WD loader had single acting cylinders so each had one hose and tee'ed together and to remote line that run beside seat base to rear of tractor.
If you do not have a remote under the seat....look at the top of the hyd valve assy- where the two hoses from the lift cyl attach- there is a third port. I should be to the (left?) front of that casting. That port is where the remote line would attach- you can remove the plug and add a hose connector there.
BTW- you don"t need that extra remote valve- just hook the hose to the port and use the lift lever to activate the loader.
Thanks guys, sure do appreciate the memory jog. I'll seee if I can get it hooked up this weekend when I get home. Need to spread some horse apples if it freezes up a little. Keith
