mounting F11 on M
I am mounting a F11 on an M. I noticed that the nose of the tractor is off to the left side of the loader. Upon looking at the angle braces which bolt to the frame channel I noticed the left side angle is an inch shorter than the right side. To center up the loader on the frame I need to lengthen the left brace adjustment by the amount it is short. My question is After I take the left angle brace loose can I hook on the to frame of the loader up at the head (just back of the bucket mounts) and gently move it over untill it centers up or do I have to dismount the unit from the M and start all over???
yes you can 'adjust' the loader without removing it.leave the bucket on the ground and push the loader to where it needs to be.those braces should be adjustable
My personal opinion about the best way to adjust a F-11 is with a cutting torch. First thing I did with my MTA when I brought it home was take that loader OFF. It ended up it the scrap heap.
But you know what the say about opinions...
Ben
