mounting plow on model G
I bought a mounted plow for my G allis. Does not have hydraulic pump so it will have o be a manuel mount unless I can figure out to put a pump on the tractor. What do I need to mount the plow on the tractor? Any help will be greatly appreciated. Thank you. Jerry
First I hope you have the master hand lift. The plow clamps to the front axle with 4 bolts. I have some pictures if you need them. Russ
I saw a nice AC "G" at Portland, Ind this year with hydrolics..set up as a very nice road-grader...
He had mounted a power steering pump, driven by the fan belt and had a multiple-spool valve on the rt fender to control blade tilt, height ( cylinder on each side), etc...and had a front blade on it too..
I may have a couple pics of it, if you want to see it..
Ron..
I have a disc plow on my G and it does not bolt to the front axle. It has a bar that runs to the rear draw bar which does the pushing of the plow. I also have a copy of the instruction showing how to hook it up. It works off the manual lift. If you would like a copy I will be more than happy to send it to you.
Will try again to upload in here..not getting very far...
Ron.
Nope, screw it..send me an E-mail address if you want these pics....!
Ron..
