Mounting points on a engine?
Brian Ski
I have a Farmall H and going to swap the engine. Where do you bolt a chain to the engine? There are not a lot of bolt holes in the block? Not a fan of just wrapping a chain around it. The motor mount holes are almost at the bottom of the engine. (too top heavy) There is the generator bracket mounting bolts. But they are a little small. I sure don't want to break anything.
Anyone have experience? It is a small engine, but not very many bolts on it. There are the stud bolts on the mounting plate, but not sure how strong the studs are.
