Moving Brush
Well the brush will rot out and fall down in a year or 2 and you can at least see what your doing if it needs cut that bad sooner. Then for the forks bale forks are to short. I ahev tried them in the past on the loader. Forks on the telehandler are to short for real brush hauling as you don't get much on. You want forks about 5-6 feet long for brush if you want to haul much iof it at a time. A loader with a big bucket like a snow bucket with a grapple works well if you had one. Or hire a brush mower to grind it right down to the stubs.
as double07 posted below, rear mounted 3 point brushforks are very common in the orchards here in pacific NW. with the weight on the rear, the traction is where you need it as well as stability. the
photos below are of the brush fork my dad built in 1960s and is still very well used to this day. as you can see, the headboard and tines are all bolted on for when the blade is used for snow and gravel and
dirt or any other tasks during the year. and with the length of the blade frame, the brush can be stacked in decent piles. the previous method of moving tree and cane berry trimmings was tossing onto a flat
bed trailer by hand, driving to edge of orchard or canyon or burnpile, and hand unloading. requiring at least a tractor driver and one or two throwers. at this time, the family was renting approximately
100 acres of nuts. and with trees planted 20 foot square from each other, made for an average of 100 trees per acre. that was alot of hand work every year of clearing out the limbs after the hard job of
tree trimming. Dad says he can not guess how much faster the operation became with the brush fork. Dad said just traveling thru the orchard with a solo tractor instead of tractor and trailer was faster,
and the work completed much faster, and you could start the brush fire and keep feeding the fire with each brush pile instead of tossing in one limb at a time without getting smoke or ash in your eyes.
brush fork is on Ferguson TO30 with sherman 3 speed in overdrive. dad said he was very proud of the outfit and it really worked great. Plus he said it was at a time when most front end loader tractors were
much too tall to fit the the orchards safely, and if they did fit down the rows, they were tippy and dangerous on the the many hillsides.
I really like the looks of your brush forks mounted on a back blade. I'm having a little difficulty in understanding the size and construction. I found a link to an owner's manual for 1972 vintage Little Rhino back blades. At that time, they were made in both 6' and 8' sizes. They seemed pretty stout with 5/16 steel blades. I'm a hundred miles away from my county place, so I can't look at my farm store back blade. I suspect that it much lighter,
Can you tell me the length of your back blade? Do you have any idea of what kind of material was used for the tines and how long they are? I can't really see the detail of how the headboard and tines are attached to the blade. It looks like brackets or sorts have been welded to the lower part of the blade where the tines are attached. The blade seems to have some sort of lip on the top where the headboard and braces for the tines are attached, but I can't see the detail.
Owners Manual
Sorry, not my pic.
My first 40 years were in SW Michigan fruit belt. Every farmer with a sizable orchard or vinyard had pretty much a brush picker as pictured.
Most were mounted on the front of a Ford N size tractor or a Friday Tractor since those were built 20 miles away.
A narrower version was for the vinyard trimmings or new orchards going with hedge row planted dwarf fruit trees.
Most just had 2.5 inch pipes for the tines.
I am happy to measure some dimensions this weekend for you.
And take more photos.
There are no extra brackets welded to cutting edge. The blade is stock and usefull. The brush tines bolt on with the cutting edge bolts.
One last question.
If it takes me till the weekend to respond. Should I continue to reply to this thread or start a different one?
(quoted from post at 00:35:12 02/02/23) I am happy to measure some dimensions this weekend for you.
One last question.
A new thread might be a lot easier to find.
Any additional information you can provide would be much appreciated.
I'm a retired city slicker--desk jockey (and not a farmer or engineer.) After thinking about your design overnight, I've had a couple of thoughts. The first is that I may be trying to carry a much heavier load than is typical for orchard pruning. The second is that a back blade probably isn't designed for lifting loads. You seem to be using a top-of-the-line blade that has withstood the test of time. My farm store cheapie might be less forgiving.
(quoted from post at 13:11:22 02/01/23) as double07 posted below, rear mounted 3 point brushforks are very common in the orchards here in pacific NW. with the weight on the rear, the traction is where you need it as well as stability. the
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto146434.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto146436.jpg>
I have two snow plows in a fence row and always was going to build one like that. My drive is higher than the edges, some points are 3' higher so always thought a longer arm on one side so I can stay centered on the drive and roll the snow off the edge. I am going to utilize your photo and get mine built this summer. Really like the removable forks also. Thanks to you for posting what your dad made!!
(quoted from post at 04:50:28 02/02/23) Here's how I move brush
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto146453.jpg>
That is an ultimate goal of equipment for me (the tractor loader and grabber).
And a year later set fire to the piles......
Then installed teeth on my case 830 and hauled the remains to the burn pile..
Bob..
