Moving snow on the cheap
soder33
I needed a cheap and better way to move snow this year after the large amount of it we had last year here in Western Wisconsn. I own a Ford 8N, that was not being used and was stored at my Brothers.
I found an old 7 1/2 foot Myer plow on Marketplace to mount on the 8N. It needed work and I welded up patches made from an old JD riding lawn mower frame. Then I fabricated a bracket to mount to the frame of the loader and welded it in place. I used the loader arms with the existing chain as the way to raise and lower it.
I am using a pin to adjust the angle of the plow, but am looking at using the hydralic angle cylinders that came with the plow once I get a second 2 way valve mounted and plumbed in. I also got a set of chains for it that a friend of mine said I could have. He hadn't use them since he got his first FWD tractor on the farm. They were too large, but I was able to cut them down to fit. The best part, it works the way I want.
Total price, $80 so far.
I do some snow removal for a couple of places, got a 7 ft. snow plow blade and mounted it to my loader. Also have a 8ft rear blade on the tractor, can move a lot of snow in a short time with this setup. Note a good pair of off tire chains is a must with my setup.
It is looking pretty good so far but a word of caution. Be gentle when you plow. Your frame looks as if it could end up as a twisted mess of spaghetti. Just use a little caution. Especially that blasted wet snow.;)
If your 8N has been 12 volted, you can use the Meyers pump unit to both lift and turn the blade. The Meyers takes less electrical power than the Western unit, as the Meyers has a motor with permanent magnets for the field. If that came with your blade unit, then you have a good and cheap solution.
There is another possibility for getting the turn function without getting a 2 valve setup. We use a solenoid controlled hydraulic switching valve (12 volt) which makes one hydraulic pair of quick connects into a double control serving 2 separate hydraulic functions. I think we bought our switching valve from Surplus Center (formerly Burden's Surplus) in Lincoln Nebraska IIRC.
We have a TW10 Ford set up with a 9.5 ft front blade and a 9 ft. rear blade with both blades having lift and turn functions. With the hydraulic switching valve we control either the front or rear blade turn from one pair of remote cylinder quick connects. We have used that setup for more than 20 years trouble free. Now that baby will move snow!
Paul in MN
Find out if angling the blade doesn't push the front end the other direction before you put a lot of money in hydraulics.
George
Why not just mount the blade to the loader frame ? Then you can push it up into high piles too.
