Mowing a hillside with a discmower
I have a three acre field I been brushhogging I was thinking of bailing it but it's all on a hillside maybe twenty degrees or a little more was wondering if the cutter bar could be damaged due to oil running down to one end of the bar while mowing any thoughts
I have heard that concern expressed before, don't know if there is anything to it. From personal experience, if we didn't cut hay on a slope, we wouldn't cut much hay. For three acres, I sure wouldn't have any hesitation.
A very real chance of serious damage for most makes and models of disc mower. Posting what you have might allow those with expertise to give valuable information as to what may or may not happen. Do you have access to a sickle bar mower?
Some brands of disc mowers such as NH 617 & Vermeer M7030 have modular/segmented cutter bars that each module contains it's own lubricant. Cutting on slopes with these types should have less of a lack of lubrication problem than the other type cutters
Two types of mowers.
One big pan under the discs shares oil all the way across, the gears all spin in that pan of oil. If you mow on a good hillside all the oil runs to one end. The gears tend to carry the oil back up again and get oil, but the upper side will eventually get a little dry. The manuals on these have recommendations of how long to go before leveling the bar for a couple minutes to get the oil distributed again; but on a three acre patch you should be just fine. The concern is if you mow road ditches and drive a half hour with the end of the mower up the whole time.
The other design of mower is individual segments, each turtle is driven by its own independent gear set with its own resivor of oil per turtle. These aren’t affected by a slope. But you have a lot more dip sticks to check!
So to answer your question exactly, it is something to be aware of with certain models but a 3 acre field you likely will get the bar flattened out from time to time and not have any issues at all, check your manual but I wouldn’t be worried about it as long as you get the bar level every 15 minutes or so I think is the common recommendation.
Paul
For every pass you make in one direction you will have to make an equal pass in the other direction. Bar tipped down one way, bar tipped up the other way. So no problem. Even if mowing miles of road ditch you have to level off for field approaches, going around road signs, around culverts. I can't imagine a situation where you are mowing more then 15 minutes without leveling bar for something.
I would think the manufactures of most machines would make it useable in all directions. Except Fords Model T. On steep hills the driver would need to back up, to make sure gas flowed to the carburetor. Stan
I would be very careful mowing a hill side. We have had three people killed in this county. In the four years I have been here.
Yup. Have the bar on the uphill side, drive a little slow, beware of gopher mounds, have good tires that won’t blow out and good brakes, think through what you are doing. Stop and think before reacting to something and putting the weight on the downhill side.
Paul
Kuhn cutter bars back in the 1980's were noted for failure from lubrication starvation. Not a lot of long fields in certain parts of NY so the bar was not starved for say 10 plus minutes at a time. JD and NH used Kuhn bars in some of their respective products back then. It all depends what the OP is running as I said before. Most likely anything made in the last 20 years has that aspect addressed from an engineering standpoint.
