JR.Fyre
I just got the starter pull'd on my wife little red cub
and I locked it down in the bench vise, I hook'd
the battery boster to it and it acked like it was not advancing in to the starter cone, So this tells me, it may be a bindex spring,or may be a shaft, the starter gear teeth looks good and the fly wheel teeth look good so I am hopping that is
all. But it probley would not hurt to have it compleaty rebuilt, For $60.00 or less, thats cheaper than a new one:: Up to $600.00 for a new one.That wont happen, well bud got ta go,
say hi to the your wife, Havs a good one.
JR.FRYE
Is that the type with a soliniod that has the plunger that is pulled by it or the type of bendex that spins it out. If it is the plunger type the solenoid maybe bad and that is a cheap easy fix. If it is the bendex type it may just need a new bendex
There is a pull rod that is hooked to it and to start it you pull the rod, I think that is what you are asking.
JR.FRYE
Ok then it sounds like it doesn't have a solenoid on it and the bendex is the spin out type so you may have a bad bendex or your jump start thing may not have enough zap to spin it up good or your starter maybe draging some and not spinning up 100%
