I noticed some off and on exhaust popping yesterday. It's the same sound as when I shut off the fuel to run it out of gas when I shut her down. I pulled the inlet off and ran some gas into a can, good flow. So I took off the carb imlet fitting to check the screen, and, no screen.
There is one at the glass bowl outlet on the tank.
When I put the fitting back in the carb, it tightened up 1/4 of a turn past where it needs to be for the inlet line to connect. I turned it a bit more but I didn't like the feel of it, like the threads were going to strip. So backed off and lined it up to the line and attached it, but the threads in the carb leak a bit.
I need to get the screen anyway, should I get a new fitting? What will strip first, the brass fitting or the body? Is the body iron?
Thanks.
Thanks.
