MT, Hydraulic Seals
M. Davis
Does anyone know where I can get the two hyd. seals for the lift arm shafts on the Touch-O-Matic Rocker shaft.? Part numbers, M431T, M1104T. I checked with the local John Deere dealer, Contrary Acres and a local hyd. shop with no luck. Any info. would be appreciated, thanks.
JDparts.com shows them as Deere having them available. M431T $9.15 each and M1104T $12.46 each. Guess your dealer did not want to drum up some business.
Yes they are available,,and sorry to tell you this but they will still leak,,Darn it,,there was a thread on here a couple years ago about a guy cutting the shaft for an O-ring that helped with this problem...
Thanks for the information. I checked with another Deere Dealer and the parts will be here tomorrow. As for the seals still leaking, a small leak I can tolorate, it's the constant run I'm trying to stop, ha, ha. Again guys, thanks for the help.
