MT Transmission Specs
I was wondering if anyone knew of a site that had some specifications of amount of oil in the transmission of a MT. Also for the touch-o-matic. I looked on external_link and was unable to find anything about the transmission, only about the engine. I was also wondering, because I don't have a manual, whether the plug on the middle right(looking at it from the front) of the foot rest, right behind the clutch is a drain plug or a check plug. And finally, do the final drive gears and the drain plugs on those have separate oil from the rest of the transmission?
I appreciate all the information, and I don't mind if you have more than just what I've asked either!
Thanks,
Jake
The transmission takes 7 1/2 quarts of SAE 90 oil. The drain for the transmission is under the footrest on the clutch side. It fills on the other side above the footrest. When it is to the top of the filler hole it is full. The T.O.M. takes 5 quarts of SAE 10w oil. On the back of the T.O.M. you will see a pet cock open it up and the SAE 10w oil should run out, when it does it will be full. Run it up and down a couple of times and recheck it. The final drives use 3 1/2 quarts of SAE 90 oil, and are seperate from the trans. The drain is on the bottom of the final drive. Fill the final drives until the oil comes out the fill hole on the back of the final drive.
MIke
