multipower spacer for 35x
This question is probably best answered by Masseynut. I am about to split my 35x and do the clutch and lockout the multipower. I found the spacer size in a previous post , 69.5mm od 54.2mm id and 2.9mm thick. This post was for a MF65 and I need to know if that size will also suit my 35x. Thanks
Hello,
Yep, that spacer will still fit in place of the spring, to lockout the over-run clutch in your 35X. In fact, that spacer will serve the same purpose in all Multi-power transmissions,
Evan.
