murray 20 inch push mower carb replacement
hey everyone hope all is well, i am having a hard time finding a carb part number for a 6.5 hp briggs motor on a murray push mower, anyone know something i dont know? they dont list the carb on the briggs website, here are the model and serial
model 206006X30B
serial 7413604704f00397
-The model and serial given are for the Murray Mower. (At least the number with the X in the middle makes it look like a Murray model number.
-You need the model and Type and (sometimes) code number for your engine.
-Very early Briggs push mower engines the numbers were stamped on the flywheel cover behind the air filter. Later ones stamped the number on the end of the flywheel cover above the spark plug. Most of the overhead valve engines had the numbers stamped on the flange just above the muffler, where it is sometimes covered by a plastic trim cover. If yours has a plastic carburetor, the early numbers were on the carburetor support bracket and later they were stamped on the crankcase opposite side from the carburetor.
