Must be Monday!
kcm.MN
Location
NW Minnesota
That green contraption in the middle between the mast and the hay seems to extend the load out pretty far probably be better without whatever that is.
Paul
My maternal Grandfather had his own machine shop- lathes, mills, ginders, etc. Did tool and die repair for local die casters and Bendix factory.
One of the last tools he bought was a huge Cincinnati mill of some kind- delivered in a former Sears/Roebuck box truck (remember the teal/aqua green Sears trucks?)
He hired the local lumber yard to bring over their forklift- similar to the one pictured, but open station. The forklift guy slid under the machine and got about the same result. So Grandpa, (6'3"/300+lbs) and the delivery driver, who made Grandpa look skinny, climbed up on the hood of the forklift.
I wanted to join in, but Grandma was having a conniption fit already, so I was stuck on the porch, watching. I know they got it on the ground, but I don't think he could get it inside the building. It ended up installed in one half of the two-car garage next to the machine shop.
The green thing may well be a scissor extension, similar to the one below, so the machine could load a truck or trailer from one side. Not that it appears it could handle the load when extended.
It is a Manitou fork lift truck rated at 2.5 tons lift capacity to 12 feet or 1.5
tons lift capacity to 18 feet. It is set up in the 1.5 ton position and it has got a
tipping backplate between the mast and the bale handler. I fitted a lot of these
types of bale handlers on these forklifts but I allways took of the tipping
backplate first. That model of Manitou had an unladen weight of 5 tons, 2.5 tons on
each axle with no load on the forks. MJ.
Riding on the back of a forklift to help counterbalance it (hold it down)
is noting but deadly . See the youtube video. PLEASE if you are sensitive
or squeamish or have young children looking over you shoulder DO NOT view
this video @ 1:20. I am not trying to offend any body but you need to see
how easy it is to have a deadly acedent or be maimed for life doing such a
stupid thing -- perhaps you will remember this next time you see some body
climbing on the back and stop them .
https://www.youtube.com/watch?v=pzjKuDFZmFY
Untitled URL Link
