MW nine speed cable
alliskid
Purchased a 45 H with a cable shift M&W nine speed. The tractor has been sitting for sometime so the cable is froze up. How can I gain access to the cable in the transmission to change it? Will I need to pull the top of the transmission off or can I get to it threw the belt pulley cover?
Should be able to get it loose inside through belt pulley gear box opening. Then remove bottom cover to rear of hydraulic unit to get loose where it passes through transmission wall. If I remember correct it passes through and anchored to hollow dowel pin on a H.
