my 300 dilema
.Some time during Xmas vacation ,while I was operating my grader, my grandaughter was dragging an aparatus to smooth the berm left by me grading. After a time she appeared at the shop with the tractor spouting steam like a tea kettle. She then said "I told you yesterday ". So I let it cool off some and later I added some water to the system. It seemed to be moving the coolant and I wondered if I had blown a head gasket?I parked it and let it set for a spell and today I loosened the drain plug and wanted to see if there was any coolant in the pan. But I dont think I quite made a proper assessment as the drain plug came loose and the oil came out, needed changing anyhow. The questions that come to mind are: should I add coolant and let it stand with no oil and see if there is a coolant leak? Should I refill and operate to see if the haed gasket is KAPUT? or WHAT. THANK YOU Gentleman in advance. CC
Pull the plug, put a pan under it. Put coolant in to top. Put 7PSI (NO MORE) on the fill neck. then wait for the pressure to drop, coolant to appear, or (hopefully) none of the above. JimN
