My 8N paint
RGR
I'm going to be doing a some painting on my N I know I won't be able to match original colour 100%, but will do the best I can. Just want to know the colour scheme, like rad cap steering wheel seat and other stuff that might be helpful.
RGR,Here is some info I had about that.
Center housing
Red
Electrical- battery cable
unpainted
Center housing- touch control lever
Red
Electrical- battery ground strap
unpainted
Center housing- pedals: brake
Red
Electrical- battery tray
Red
Center housing- pedals: clutch
Red
Electrical- distributor
Red
Center housing- rear axle housings
Red
Electrical- gauges: (ammeter) bezel
Black
Center housing- rear axle hubs
Red
Electrical- gauges: (oil) bezel
Black
Center housing- rear axle lug nuts
plated
Electrical- gauges: (proof) bezel
Black
Center housing- rear brake drums
Red
Electrical- generator and pulley
Red
Center housing- three point hitch
Red
Electrical- ignition: switch and key
unpainted
Centerhousing- drawbar
Red
Electrical- spark plug wires
unpainted
Centerhousing- PTO lever
Red
Electrical- spark plugs
unpainted
Centerhousing- PTO shaft cover
Red
Electrical- starter
Red
Electrical- starter button
Red
Electrical- wiring harness
unpainted
Engine- carburetor
Red
Sheet metal- dash1
Gray
Engine- carburetor air cleaner
Red
Sheet metal- fender mounting bolts
plated
Engine- carburetor choke knob
plated
Sheet metal- fenders
Gray
Engine- carburetor fuel line
unpainted
Sheet metal- grille
Gray
Engine- carburetor fuel shut-off valve
unpainted
Sheet metal- hood
Gray
Engine- crankcase breather cap
Red
Sheet metal- running boards
Red
Engine- fan belt
Black
Sheet metal- seat and spring
Black
Engine- fuel system: sediment bulb
unpainted
Sheet metal- side panels
Gray
Engine- fuel tank
galvanized
Steering- front axle hub
Red
Engine- head, block, and oil pan
Red
Steering- front axle lug nuts
plated
Engine- linkage
unpainted
Steering- front axle spindle housing
Red
Engine- manifolds
Red
Steering- radius rods
Red
Engine- oil filter
Red
Steering- steering wheel acorn nut
plated
Engine- radiator
Black
Steering- tie rods
Red
Engine- radiator cap
Black
Transmission gearshift knob
Black
Engine- radiator fan
Red
Transmission- gearshift
Red
Engine- radiator fan shroud
Red
Transmission- gearshift boot
Black
Engine- radiator hose
Black
Transmission- housing
Red
Engine- throttle lever
plated
Wheels- front rims
Gray
Engine- solenoid
plated
Wheels- rear rims2
Gray or Silver
Wheels- rear centers
Gray
