My compressor motor
37chief
Location
California
I have a single cylinder gas motor to run my air compressor. The compressor sat for a few months It failed to start. I found the float needle valve rubber tip stuck to the seat. I freeded it up, and it ran fine, but had the same problem next time I started the motor. what would make the float needle valve to stick? Stan
shut the gas off and let it run till the carb. is emty Problem solved till you get a new needle. Roy from northwest Iowa.
Probably getting softened by the methanol is todays gas. Maybe you can find some 100% gas. That or change to a newer made needle that is compatible.
Methanol is not (now) in gasoline AS far as I can assess. Ethanol is and it can have an affect after a while, but Methanol just eats things. It was tried in the 80s in CA, and Colorado. I repaired 20 Hondas and several others with ruined plastic and rubber components. Jim
When ethanol gas came to my area I started having problems with float valves in my old tractors and small engines. A dose of Marvel or Essentialube in the gas has done the trick for me. In my case it’s less hassle than stocking e free gas.
Oops, I know better than that. Methanol is used at the race track, ethanol at the gas pump.
