My Recent Project
2510Paul
I widened the tires in my 4250 2? on each side and added a set of weights. First furrow was only cutting 16 inches.
I replaced all the excessively worn parts on my Case-IH Plow. Shares should go at least another year. I also replaced a lot of loose or incorrect bolts/nuts.
I plan to put a real jack or adjustable jack on it. Someone did that on my JD 4200 plow and it really helps for hitching.
Now if I could just find a JD Roll-Over Valve for it like on my JD 4200.
No, but I had adjusted them two years ago. Even the rack and pinion worked. But I have freed some really tough ones.
Well, I believe it rolls as deigned. I am spoiled with the JD as I only have to move the SCV once, not twice and carefully time it to complete the roll.
Right now I don?t have the Pilot Operated Dual Check Valve in the circuit. I am going to put it back in and see if I see any difference.
Thanks SV for your help last year.
Paul
Paul
That?s different than either of my rollover plows . The one rolls with a cylinder that turns a sprocket to roll the plow the other one has a cylinder that hooks to a gear that turns the plow . Have you got the manual for the plow is any help ?
