My TE20 ate its starter
78CJ
Was turning over yesterday morning and after a couple rotations it make a loud clunk and everything locked up. Pulled the Lucas 6V starter and the gear is shattered. I looked up a new starter and got sticker shock! Is it possible for an electric motor shop to replace the gear?
Ryan
I have never asked our local electrical shop if they can do that but I would certainly ask. A phone call is fairly inexpensive.
When you are about to assembly STARTER to ENGINE see picture of measurement:
FERGUSON TEA 20 Tractor PARTS STARTER 937-585-9904......(e-bay)
25518 25519 6 Volt 9 Tooth Starter for Massey Ferguson TE20 If you have any questions on this Item, please Call us Toll Free at 1-888-6PARTS6, 1-888-672-7876, or 517-347-7033:
I have NO connection in anyway with the above SALES, happened to see info on NET:
OLD PARTS BOOK INFO: 1957:
#19 A 829-842-M1 PINION ASSEMBLY Tractor S# 200001>:
#19 B 829-912-M1 PINION ASSEMBLY Tractor S# <200001:
#18 A 829-843-M1 Starter Drive Assembly Tractor S# 200001>:
#18 B 829-915-M1 Starter Drive Assembly Tractor S# <200001:
No assurance that Part #'s are still valid:
Well worth pursuing the repair , Lucas 6 volt starters are very expensive as you've found out but replacements aren't anywhere as good as the old ones .
The gear probably split through wear but it might be worth having the whole thing looked at .
Check the back of the ring gear for wear and missing chunks , a six volt starter pulls up against the gear from the rear rather than pushes from the front like twelve volt ones .
I took the starter to a local shop I know well. Had it fixed up in a day. He also converted it to 12 volt as he said that they have repaired many unconverted starters that have detonated from spinning double the speed when impacting the ring gear.
