My tractor hauling set up
savsmm
I was hauling my tractor before Xmas and thought I would just share my set up.
2005 Dodge Cummins, 2010 Sure-Trac 18'+2' trailer, 52 MM UTS. I had a deck over trailer before, I really like how this one sits low, easy to load, tie down, easy to step on and off, and the tractor sits low to the ground. Only thing I wish I had was radial tires.
Looks good.
Have you run the numbers on your truck and trailer rating plates to see how it comes out?
Good looking rig, I have a 20 and 5 deck over gooseneck, 15000 gvw and a 250 Ford 5.4 gas. I wished I hadn't been so cheap and bought a diesel. I thought about a trailer like yours but I was scared my tractor's wouldn't go between the wheel wells.
Nice looking trailer. I'm envious of you. I'll betcha if a guy owned both a deck over and a trailer like yours, the deckover would sit unused most of the time. Jim
Just bought a 18'+2' Load Trail implement trailer (not gooseneck) and they replaced bias with radials for $100 total for all 4. Can't believe Sure-Trac dealer wouldn't have done the same. Although , our Sure-Trac dealer not only wouldn't deal but outright lied about three things promised over the phone. Otherwise may have bought one. Load trail is just as good or better and one #ell of a deal. Very happy with it.
My situation would be different, I couldn't use a trailer of his style although my MM puller would fit very nicely on it and those trailers are much easier for on and off, too.
I like your setup!!
Here was my last haul '09, out of the deep south, getting ready to unload.
Not too heavy of a load for my 1/2 ton, thanks to the missing parts. I will be stepping up someday to a 3/4 ton diesel.
No it is not I make a living flatbedding in Mo and that load will not make it thru a DOT insp or across a scales.Look it up in the DOT manual
my truck is tagged for the total weight of truck and trailer, that is what they do in IA. truck weights about 6900 lbs.. trailer empty weights about 3500 lbs and is a 10,000 lbs trailer (5000lb axles). that gives me 6500 lbs of hauling cap. tractor weights 6500 lbs with all my weights on it, so i am at max rated capacity of my trailer if you figure no weight on the truck. I figure the hitch weight gives me my cushion of rated capacity. so i figure i am at 17000 lbs total weight, give or take. i tried to read all the regulations before i ever bought this trailer. from what i have ever read, i am ok for weight and tags, even if it was up to 18 or 19K, as long as i don't have over 10k on the trailer axles. never been stopped, so guess i have never been tested.
i could have upgraded to radial tires when i bought the trailer, just didn't think it was that big of a deal. but now, i wish i had. it does ok, i just think it would ride a little better with radials. they will be on wish list when i need new tires.
i have four chains on the tractor, two in the front and two in the back. each chain has a binder on it. the front, i wrap around the front axle, they are in the 'middle' as that is how they 'pull' and tie down the best. guess, if the book reads must be tied down at each corner, i would have to see if 'corner' is defined. i have tried to tie town wrapped around the frame, but the chains hit the front tires and that doesn't hold the tractor well. still would have to understand 'corner' to know if even around the frame rails would meet the 'corner' spec. it would gain me about 5" to 10", but would it be considered 'corner'. who can define corner?
i didn't know that straps couldn't be wrapped on the outside of the rub rail, so i don't have my extra weights tied town correctly in the pic. don't usually haul my wieghts as shown in the pic, just did this trip. now i know that straps have to be on the inside of the rub rail.
my tractor rear tires have about 1" clearance on each side by the fender wells, close, but the suretrac had one of the widest specs between fenders, one reason i bought it and the other was the power coat paint. it is close, but i just always line up the inside of the front tires three floor boards in, and it goes right on. i am sure one of these days i will get into the fender, but at least i know who made the mistake!
my set up works well for me. i only haul my two tractors (this one or a MM GTB stock that weights 6500 lbs as well). From what i see at most of the pulls i go to, I am a lot closer to being legal than 90% of guys, but close probably doesn't count if i get stopped.
(quoted from post at 16:54:15 01/14/11) One chain and binder on each corner that tractor wieghs over 5000 lbs.
Sorry guys, That tractor is under 10,000 lbs so it can be tied down according to heavy equipment in Section 393.130 (4 tiedowns) or using section 393.128 (2 tiedowns)
Read the exact rule here:
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=r49CFR393.128
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=r49CFR393.130
