My U won't shift.
Dave in MI
I used my U today to work a little ground, nothing much perhaps 15 minutes. When I was done I parked her back in the barn for the night. It so happened I needed to move her a little later and the gear shift lever just flops around.
Could some one please tell me what it is going to take to get her back in working order. I really like this tractor.
Thank you.
Dave, sounds like a simple problem. Remove the shifter from the top of the transmission and I think the problem will become apparent. I think just 3 or 4 bolts will allow the removal.
I am just trying to get a look at the tractor. Some Us you have to remove the whole tranny cover to repair the shifter.
This UTU's serial number is 325432U which I think puts it 1949 or older. There is about a 4' cast plate over the transmission that looks like it will have to come up or off. I was hoping I could get the shifter out and go from there.
Another question, I want to make sure I get it sealed up again, if is there a gasket under there or was a type of gasket sealer used. I don't want to take it apart until I'm sure of putting her back together right. Sorry for the rookie answers, my father bought this new in I thought 1948 at least that's what I remember him telling me that it was born the same year I was. I've worked on her before but never had this problem, dad passed away a couple of months ago so you fellows are my resource.
Digital camera is down right now or I would show you pictures of that plate.
Thank you for your help. I'm sure I'll have more.
It's not a big job to remove transmission cover. Just run a bead of silicon on gasket when reassembling. Not a common place too leak as it is the top. Probably one of the shifter rails out of place. Just realign.
Thanks everybody, I'll get at in a day or two and let you know how it went. I really appreciate your help this tractor means a lot to me.
I have my U stripped down and I'm ready to lift the plate. When I was taking the clutch lever off I started to wonder what all will fall apart inside when I do this. Are there any surprises I need to know about or will everything just fall back in place once the shifting rail is back in place?
Thanks for your help.
Dave,
No, nothing is going for fall down, out, etc. Here is a picture of my U trans on it's nose. The top cover parts will be intact also.
Dean
In this picture I don"t have the plate off just lifted up from the back. Notice the plate with the two lateral pieces laying on the shift rails, it"s just laying there not attached to anything. I can"t imagine that is the way it"s supposed to be.
Here are two pictures of that plate.
I"m thinking I"ll remove the plate and find where it was attached to the plate, can you tell me if it has been damaged.
Dave,
Here are your pictures, I am not familiar with the item in the top picture. Where did it set in the transmission picture?
Dean
Dean - I think I have this figured out. I've put some labels in to help explain as best I see it. (A) and (B) were separated at line (C) it also appears there is a piece missing at (D). I went down in the transmission with a magnet and can't find the missing piece (D), my brother thinks it may be hung up in a gear somewhere. We're hoping if we roll the U backwards it will show up. I see now the reason for this, it is to keep the shifter in line over the shifting rail it us using.
I should have taken that piece of gasket out of there before I took the picture.
I hope this explains things a little better. I hope I also have this picture thing figured out.
Dave
Dave,
Here is the part that you are needing. Item # 6 on page 93 of the parts manual, Part # UT 207 B. In my G-VI parts manual this is called a "Bracket - separating".
Sorry for the large file, that is how my scanner works.
Dean thanks for the picture, I have one ordered out of Ohio and should be here in a couple of days. I don't like her broke down but I'm having fun working on her. I'll let you know how it's going and thanks again for your help.
Dave
