my winter project is done
formerly ny bill
Just before Christmas, I got a chance to buy a 460 High Utility that I drove about 60 years ago. It was sold as having a dash wiring fire and a bad RH wheel and tire.
When I got it apart, the engine was set up. One sleeve was pitted and had to be replaced, along with new rings and bearings.
The fuel system was horrendous. The gas tank took 3 cleanings and then sealing. I threw the sediment bowl away. Carburetor was rebuilt and is still acting up. I'm using a 560 carb on it so far. I replaced the bad wheel with a rim and tire I had on hand.
Replaced the non-working gauges. When I put new antifreeze in it, the top tank seam had a leak.
Its a good thing I wasn't getting paid by the hour. I couldn't afford myself.. But I drove it around yesterday. Good feeling. After i use it some and see how many more leaks it has, I will worry about possible paint. It should work well on the seeder and rake.
Looks good. Still do not understand the wide wheel settings. They take a lot more shed space and turn so much wider. Ours are all set for 30 inch rows except my brothers 7140 which has the front wheels about 8or 10 feet wide. He claims it turns shorter by 3 feet in a circle that way.
I have a pair of 656 Hi Crops, gear drive is a tractor my dad bought new in 1968. 656 Hydro I bought in the 90s. Also have a 350 Hi utility. Its like a
disease...
(quoted from post at 07:48:36 04/02/21) I have a pair of 656 Hi Crops, gear drive is a tractor my dad bought new in 1968. 656 Hydro I bought in the 90s. Also have a 350 Hi utility. Its like a
disease...
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto83715.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto83716.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto83717.jpg>
Amazing work! You're doing fine! Surely he saved a lot of money on the fact that he restored an old tractor, and did not buy a new one only from the assembly line.
38 rear tire on bar axles, longer front spindles vs 30 tires on bolt on rims. Everything above the spindles is same as a regular utility. I took a picture of the Hi Utility next to my utility parts donor.
Looks like your time was well spent. You now have a useful tractor. During the late 60s and into the early 70s on most farms around me, the big tractor was in the 50hp range. And backed up by a few older tractors in the 25-35 hp size. These tractors were a good fit on most farms, planting small grains , harvesting small square hay bales just didnt require a big tractor. Always somebody in the neighborhood that would have a 100 hp tractor and a two row chopper with wagons that need to go out doing custom work to help pay for their big equipment. And it was never a problem to get your corn chopped if you had cash in your hand to pay with. So most farmers had tractors very much like this tractor you have saved. They are capable of a lot of work still, if you have equipment and a operation size to match.
Bruce, the farm that had this tractor since new went from Farmall M and MD as big tractors, backed up by Fergusons, to the 460 in '59, to a 756 Custom in '68 or '69. I can remember them buying the 756, because they tried my dad's 806/ 5 bottom plow that he bought in '67 and got the 756 and the same 550 plow soon after. It was a very interesting time to grow up, watching the machinery companies' horsepower/ feature race.
I haven't actually run it through corn stubble, but I am sure the current wheel setting would line right up with the middle of 4 rows. Anything narrower would be crowding the center rows. And be less stable on sidehills.
I know the feeling of a big project completed and eager to use it. You'll be paid well with the satisfaction you get from using the tractor you used so long ago. It's good you are still able to enjoy working on a big project and then have work to do with it.
