John R in Wisconsin
I have a 1937 John Deere B with a DLTX10 carburetor. It was running funky so I removed the carb, disassembled it, and soaked it and all small parts in carburetor cleaner. I blew out all openings with compressed air. I replaced key parts with a new carb kit from Steiner Tractor, and put everything back together, and adjusted it as recommended in the instructions that came with the kit. The tractor started fine after the rebuild, but now for some crazy reason the engine will not shut off or even slow down much when the throttle lever is pulled all the way back, and the throttle lever assembly on top of the carburetor is pulled all the way back against the throttle stop pin. How can this be? I took the carb back off the tractor, looked inside, and the butterfly closes completely when the throttle shaft is rotated so the lever assembly on top of the carb is rotated against the stop pin! I don't see how the engine can keep running when the throttle disk is completely closed!! See photo.
Help! Any ideas?
Help! Any ideas?
![cvphoto105747.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto105747.jpg)
