Mysterious lever
u12mailus
I believe I have a 46 2N tractor or at least an engine block from what I read, from that year, I am a relatively new light user and had a question on a lever by the right steering arm. When I move it the transmission makes a higher frequency louder pitched sound and the tractor seems to go faster in same gear. Overdrive? I’m just trying to be as knowledgeable about the tool as I can be. What is it and how do I properly use it when working the tractor with Countyline shredder and blade. I’ve included pics. What say you fine bunch of tractologists?
img_6717-jpeg.122551
https://fordtractorcollectors.com/service/sherman-transmissions/
Smith's auxiliary transmissions.
Curiosity strikes .... my overdrive lever is on the left side
Were there different aftermarket manufacturers?
A friend has an N with the hole, but no lever - anyway to tell if a conversion is in there?
Go to the link I posted in Reply #4 and peruse the information there.
You would use the overdrive to drive the tractor a fair distance to where you are going to use it, and then out of overdrive to use whatever implement you're using.
My Step-Up Sherman transmission lever is on the Left side, knob is right in front of the toolbox (9N)
