Mystery Knobs
cruxthedog
Ok guys I have searched the interwebs high and low, and just can't seem to find a diagram or any information on these two knobs on my 8N.One has a spring that plunges the knob up and down and the other appears to be broken off, it just spins around.
Can one of you crafty old vets help a young guy out?
Thanks Alex
The one w/ the spring allows you to use remote hydraulics off the belly pump w/o trying down the lift arms. Not sure what the broken one might be.
75 Tips
Bruce
OK so on the remote hydraulics, I should have a external hydraulic hookup somewhere then?
And thanks for the 75 Tips
(quoted from post at 17:02:25 09/07/19)
Bruce
When remote operation is selected by the knob raising the hydraulic control lever delivers external pressure via the tractor's test port and operation of the 3pt lift is disabled.
ISTR that setup was used with a trencher attachment and the second knob was used to control some aspect of the trencher operation. I suspect JMOR is the guy with the full skinny and some pictures of the inside of the case.
TOH
