Mystery plug on 1020
vecair
There is a big hex plug maybe 1-1/4" rearmost of the differential right side that is leaking hyd fluid. Does anyone know how much fluid will come
out of there if we pull it to reseal? Its back by the three point arms. Don't really want to pull it if all the hyd oil is going to come out:)
If it's on the bottom it is the drain plug. There should be an aluminum washer that seals it but it is probably paper thin or gone all together.
If leaking plug is the drain plug similar to what Cliff stated the correct washer part # & spec's are shown below. Removing plug will require about an 8 gallon drain pan to contain the hyd oil.
