Roger Steele
This is probably a well worn subject, but I have an 8n that the lift won't move at all. I removed the side cover and noticed oil swirling above the pump. The control handle has very little movement inside the cover in relation to how much the control handle moves when raised or lowered. I thought I might replace the pump relief valve as a place to start, but what about the control handle? How much movement should there be on the rod when looking in the inspection cover?
I'd say it moves about an inch where it attaches to the yoke. If that. Doesn't sound like that's your problem though.
If you're dropping the pump to replace the pressure relief valve, it would be a good idea to replace the PTO seal while you're at it. And, clean the pump & sump as well.
It's called mission creep!
50 Tips
(quoted from post at 19:23:32 03/25/10)
..... I removed the side cover and noticed oil swirling above the pump.
.......I might replace the pump relief valve as a place to start,
Is the oil swirling due to the shaft turning ? When the oil is to the full level it is about an inch over the shaft . When the shaft turns normally it causes the oil to swirl above it .
With the motor turned off , you can slip a piece of hose over the end of the relief valve and out of the tranny (3' ?). Then with your hands clear of any moving parts you can start the motor and see if the relief valve is leaking off any pressure .
For a few dollars in gaskets a pump R&R is really an easy task . When you replace the pump and there is not oil in the tranny you can see if your linkage is opening and closing the valve all the way .
Roger:
See my answer to your specific question on the Tractor Talk forum.
Regarding the relief valve: You can change it through the left side inspection port without removing the pump or even draining most of the oil. I did this to a friends 49 this afternoon.
Dean
(quoted from post at 19:52:13 03/25/10)
Dean
I saw your paint reply on the other form and my question is what does a fellow have to do to become your friend , he he ????? As luck would have it I am too far away .
Most of us, myself included, have too few friends, Ken.
He brought his tractor to my place and did some very good carpentry work for me in exchange for fixing all of the things that his 49 needed. We are both very pleased.
Dean
While the PTO is turning reach in and push the control rod forward far as it will go. If it raises the lift arms then you have linkage problems. It is possible that the cam follower pin has been worn into or is somehow not riding the cam. Also be sure that the little mode shifting lever under the seat on the right side is in the down position. It is up that is the draft mode and it is common for the draft mode to stop working before the position mode stops working due to the normal wear and tear of the linkage.
Zane
ZANES LIFT STUFF
