NAA hydraulic air bleeding
Beanmedic
Sold a Jube to a fellow a few months back. I had put a top cover kit in it and bled the hydraulics. Was working fine. Now seems to need to be bled of air each time used. Good place to look for air leak?
Also he says if he puts it in draft mode the 3-point crashes down. I've not run my Jube in draft...but the "crash" down does not sound normal.
The crash down likely means it needs adjustment via manual using alt instructions not using the nuday tools.
Liss of prime might be simple lil oring at plumbing between pump and center section, if you are lucky. If it I a piston pump, it could be a shaft seal.
"Draft" mode is the first thing to get so far
out of adjustment the lift won't lift in draft.
It is caused by wear and mostly shock loads of
the ground engaging equipment striking imovable
objects in the ground and bending the draft
linkage internally. Got to pull the lift cover
to re-adjust the lift linkage.
The most common cause of the pump loosing it's
prime is the pump shaft seal on the piston
pump.
Zane
ZANES LIFT STUFF
