Unknown condition of lift operation before renovating.
I have the cover off and will check adjustments, but I'm wondering if there is anything else I should mess with ? Would it be considered "maintenance" to replace with new the gaskets and o-rings that come with a Kit ?
I've read 825 post of more that 2500 regarding "NAA oil" search. The only new seals are Aft PTO seal & Trans input shaft seal. I'm thinking I should use "multi purpose" 80W-90 GL-5 gear oil in Trans & Differential and UTF for Hydraulics. Some say GL-5 may damage Yellow metal and 90wt gl-1 is also available.
Gaining knowledge but need more
