Long post, but here's the info. 1954 NAA, 12V conversion, 1-wire 12V alternator, IC14SB 12V coil no resistor, newer points, plugs and wires, MS carb.
Used the tractor about two years ago and it started bogging down while discing. Parked it in the barn and used another tractor. Got it out a few weeks ago and got it going. That's when I put in points, plugs and wires and cleaned the carb (took off sprayed out all ports, etc.), changed oil, etc. Cranked right up, bush hogged for about an hour and started bogging and would only idle, but would idle up and run pretty good with choke under load. Checked for good fuel flow at carb. Removed and cleaned out carb (sprayed out all ports with cleaner). Fired up and seemed to run fine at high idle. I noticed the metal fuel line was close to the manifold so I wrapped with three layers of asbestos line wrap. Mowed for about an hour this weekend and it started the bogging again, would only idle unless you choked it. Went to the house and took a break for a couple of hours. When I came back it mowed for a while and then bogged again, but would idle up on choke. Ran out of time to work on it any more.
My leaning is still the carb, but it's always clean when I open it up. Could it be the coil getting hot and not sending a consistent good spark and the extra gas from the choke making it fire better? Only other thing I suppose could be the condenser. Checked the gas cap and it is venting. Also tried it without the cap, no change. Gas in tank getting too hot? Don't see a heat barrier under tank. Thanks
