NAA part missing
Mark Bei
I have a 1954 NAA that the hydraulic is not working and it is missing something. Does anyone know what I am missing?
at first glance you are missing the acorn nut on the backpressure valve.. might be more parts missing on the valve itself... here's a link to the part on the inside that gets squeezed up against the inards under the top cover..
http://home.att.net/~smiths8n/partsfs/naabackpress.jpg
from cnh.. here ar ethe parts involved:
NAA955E VALVE, CONTROL Valve Assy., Hydraulic Lift Back Pressure, Years: 01/01/1953-12/31/1954
NAA964A GASKET Gasket, Hydraulic Lift Safety, Years: 01/01/1953-12/31/1954
acorn nut and gasket:
B6734 GASKET Gasket, Hydraulic Lift Back Pressure Valve, Outer, No Longer Serviced, Years: 01/01/1953-12/31/1954
PROCURE LOCALLY Nut, Blind, 3/8"-16, Years: 01/01/1953-12/31/1954
valve parts:
NOT SERVICED Sleeve, Hydraulic Lift Back Pressure Valve{NAA961C}, Years: 01/01/1953-12/31/1954
NAA963A Ring, Snap, Hydraulic Lift Back Pressure Valve, No Longer Serviced, Years: 01/01/1953-12/31/1954
130282 O-RING O-Ring, .489" ID x .070" Thk, Back Pressure Valve, Years: 01/01/1953-12/31/1954
to see an exploded diagram hit your master parts catalog.. or the cnh parts site.. under naa, choose rear axle, and then center housing/related parts... parts in question are 11,12,31,32,46,47,48
soundguy
pic of BP valve at john smiths site
I can't tell from your picture whether or not the threaded sleeve which slips over the BP valve is still there or if it went the way of the acorn nut, but you need it. Then, there is the question of the rubber seal on the inside which is between the BP valve and the hyd assy against which it seats....is it still in place or not? Source, there are several used pars guys that post here that my have what you need.
Ditto what jmor said... I think you need to investigate it a lil further than just slapping a blind nut on it.
I gave you the cnh info about the parts.. I'd see what I had.. and what condition it was all in, and then decide what needed to be replaced.
soundguy
