NAA rear axel leaking
wmlowman
oil is showing on the outside of the rim nothing inside is ther a seal that can be replaced without removing the axel
nope.. not a shortcut style job.. though if the rear end is overfilled.. it will makes the axles leak worse.. etc.
soundguy
Its like a N,,, could B normal are could mean the axle are hub is worn out,,, if theirs any play at the hub to axle/nut when you rock the top of the wheel nuttin will seal it till you find the problem,,, if all's tight you can remove the nut (after you remove the lock'n ring) clean and seal with good automotive silicon tween the nut and hub...
8N/NAA,,, has a PIZZ poor axle hub set up,,, this set up has never worked well on anything its been used on,,, its the weak link..
WARNING all I know I read on the Internet,,, do it enuff and you can become a guru also,,, not responsible for damages,,, I read it and just pass it along,,, proceed with caution
