Naa Transmission Help
David Boys
Does the transmission need to be removed from both the engine and the rear end to be disassembled? I believe that the spline on a gear of the main shaft are failing.
Unless some one has another opinion.
When the tractor is in first gear with a load on it when you ease off the clutch the tractor will start to move and then it will pop and roll backwards then thy to do it again. With out a load it is fine second gear is also fine.
Last the ring and pinion broke while in first gear and locked the tractor up, I believe this also broke the transmission, but I can not see any damage leading me to think it is the spline on the main shaft or inside a gear.
(quoted from post at 15:06:39 07/14/14) Does the transmission need to be removed from both the engine and the rear end to be disassembled? I believe that the spline on a gear of the main shaft are failing.
elatively sure (?) that you will need to have it removed from both, but someone will correct me if I'm wrong. You might first want to examine the two areas in photo first. The coupler slides over the other marked 'teeth' or 'dentals' and I expect that to be a weaker point than the shaft/gear splines. Could get lucky and find that shifter & rails are just not moving the coupler rearward enough to engage well.
