Napa Coil Number
BigDanT
Will the IC14SB 12 Volt coil from Napa work well on a Ford 641 12 volt with no external resistor? Or is there another number for their coils I should use?
Hello BigDan. Saw your name and had to comment as it reminded me of a comedy routine I heard on the radio this morning. The guy's name was Dick Biggley but he kept mixing up the first parts of his name.
I've used several NAPA IC14SB coils that are wound for direct 12 volts, no resistor needed. I have had no problems with them. Should work for yours
I've used the IC14SB many times. But what I've found locally is
that if I take that part number into another good parts store, they'll
find me a store brand that also requires no resistor and costs less.
I've had no troubles with either of them.
Nickname given to me by the guys at work, comes from the movie O Brother Where Art Thou, not real flattering but I'm stuck with it.
