Napa fuel screen part numbers?
Jay Bama
Hey, I need the part numbers for the fuel sediment bowl screen and rubber seal.Please? Someone had posted them both not to long ago.Bein lazy and not wanting to back track.My bowl started leaking pretty bad this afternoon.Appreciate the help! Jay
You're welcome. Glad to help.
Turn the knob off fully, remove the bowl & carefully check the groove in the top of the assembly for dirt/crud/old gasket material. Most leaks on a new gasket are caused by having it seated incorrectly or because some of the old gasket was left in the groove. Or, some misguided soul may have gunked it all up w/ gasket pucky. Don’t forget to check the bowl rim for chips; if it’s chipped, you will never get it to stop leaking. Clean or replace the screen.
Put the bowl back on & hand tighten the thumb screw. Turn the gas on & look at the bowl. If it starts to fill the bowl, turn the gas off & start over; it has a leak. You will know it's sealed when gas does not flow into the bowl w/ the engine off. It won't fill with the bowl securely on because the float has closed the needle valve in the carb and there is nowhere for the air in the bowl to escape. (assuming the carb bowl is full) When the engine is started the needle valve will open and the trapped air will escape through the carb vent. If you loosen the bowl, it will fill.....and leak.
Do not open the valve more than 2 or 3 turns. All the way open gets you the 1 gallon reserve & that port is usually clogged.
All of the above assumes you have an OEM sediment bowl. If not, I'd get one because a lot of the off-shore replacements never work right & the gaskets are odd-sized.
50 Tips
