NATPA DIV. IV RULES
Bigmotors
Hello Everyone – I’m writing to clear some confusion about the “NEW” NATPA Division IV weight classes for the 2015-16 season. The board of trustees had a meeting on 07/23/15 to make sure everyone was on the same page on this issue and to give some clarification on the Division IV classes. The Division IV classes for this 2015-16 season will go as follows: The NATPA will offer both an 8 mph DIV. IV classes and an Open DIV. IV classes. Both classes will receive points for your pulls toward your championship points. You may enter both classes during the 2015-16 season. BUT, you cannot pull both classes at the same event. For Example – If you would pull the 4500 lbs. 8 mph DIV. IV class you cannot follow up by pulling the 4500 lbs. Open DIV. IV class at the same event. Basically you cannot pull both classes in the same weight class for that division on the same day. You could pull 4500 lbs. 8 mph and then pull 5000 lbs. Open. This would be okay. You do not have to be commented to one or the other DIV. IV classes until you have to choose your two classes at the end of the year for points as usual. Again, you can pull both just not in the same weight class at the same event. I hope this clears some things up about this Division IV. We are going to run both Division IV classes for the 2015-16 season as read. If the DIV. IV 8 mph has more hooks then the Open DIV. IV and if the pullers seem to prefer it. We will then adopt the 8 mph to the Division IV rules for a three year period. If the 8 mph does not go over well, we will stick to the Open DIV. IV rules for these classes. If you have questions, please contact me or any other board member on this topic. Thanks!
