Need Advice on what went wrong
old red guy
Yesterday i thought I had finally finished an eight year project that my dad had started a year before he passed away (restoring a dead SMTA). After letting it run for 30 minutes or so and driving it some while taking pictures, i noticed some thing that made me sick , the clear had bubbled up around the exhaust area on the hood. this was my first base - clearcoat project. I painted the SMTA about a year ago, but was not satisfied with the job I did on the sheet metal, so I had the sheet metal redone by a good paint and body guy I know. I used PPG base and Shopline clear and primers, so did he. What went wrong? Late last night on the internet either this forum or another one I read a post about clear problems and this guy responded with a clear he uses that will even stand up to gasoline. But I was so sleepy I can't remember what the name was and I can't find it on my history.
Plus I am ready to start on a 730 gas that i have already taken apart cleaned and sandblasted. I have used Rustolem gray prime on all small parts ,plus I intend to use TSC Restoration quality primer and paint on the tractor frame and parts, and have my paint guy do the sheet metal with the base - clearcoat system. Any suggestions on my two questions. Thank You.
I believe the Super M is supposed to have a metal plate riveted to the inside of the hood to keep the heat off that part of the hood. No paint is completely immune to gasoline. The base clear thing should have nothing to do with it, so I really don't have an answer. I assume you used the Omni (Shopline) base before the shopline clear and not another PPG product. You say you had it professionally done, I assume your painter followed the P sheet instructions, which are applying the clear between 20 minutes and 24 hours after the base, and that you did likewise, and that he sanded and sealed what you did with epoxy primer, or better sanded it all off and started over. Also, I hope you used epoxy under your base clear before you applied any surfacer, primer surfacer or high build primer, as they don't adhere well to bare metal. As to the 730, it is best to use epoxy primer and get rid of the Rustoleum and TSC primers. Only my opinion. Weird things happen sometimes.
I don't know what went wrong either. CNKS brings up a number of potential sources of problems. I see Shopline has a number of different clears. I haven't checked them all to see if they are all urethanes. A decent urethane that is fully cured should stand up to gasoline fairly well, at least the PPG OMNI urethane clear that I've used does. But it has to be fully cured. I'm not sure if you suspect the problem is due to poor gasoline resistance or excessive heat. My AC-B has an original style underhood muffler that sits extremely close to the underside of the hood. I was concerned about possible effects of high heat on new paint in the immediate vicinity so I applied some special thin insulation on the underside of the hood in the area. I used <a href="http://www.designengineering.com/category/catalog/dei-cycle/insulating-materials/floor-tunnel-shield-heat-sound-insulation">"Floor and Tunnel Shield"</a> by DEI, Inc. I don't know if that was necessary but I have never had a heat problem with the paint by using it. If you find your problem was caused by heat, you might consider something like that.
I used to have a 1984 Case. The paint had burned above the turbo. I got it repainted and installed a steel sheet between the turbo and the hood. They can burn as they come from the factory.
Things that come to my mind are possible exhaust leak aiming extra hot free exhaust directly at small area or excessive film build ( too many mils of product) Anything over 5 mils will start losing durability real quickly. Excessive film build will chip easier and will also act as a "heat sink" and will store heat as apposed to dissipating it like it should. Paint is an area where more is not better.
Rod and B-maniac bring up some good points. I have a Super M that I have not worked on yet. After what you found and with the comments of B and Rod, another possibility arises. I use epoxy followed by at least 3 coats of surfacer. I sand the surfacer and apply more if needed. I then use 3 coats of base followed by 3 coats of clear. The spec sheet calls for two, but I do not want to sand thru the clear. Although the surfacer is sanded and the clear is sanded and compounded, I am probably borderline as to the number of mils. I am going to do more sanding on the surfacer in that area, at least until I see the epoxy underneath. Something to consided if you repaint. You might also investigate Rod's heat shield.
