need advice
redbone
i'm working on a wheel horse commando 8 and i cant get one rear wheel off. the rim is rusted to the hub, and the bolt that holds the hub to the axle is really tight and rusted, i bent a craftsman 9mm wrench on it. i've been soaking it in wd40 for about an hour, i've beat and banged it for a while, still no movement. any ideas?
thanks
redbone
add some heat propane if that's all you have has worked on some for me. once the bolt is loose reinstall them but leave them loose. Some jack rabbit starts should loosen the rim.
That's all I have to offer
Kroil Oil is what I use prior to fireing up the Torch. Google Kroil Oil and you can have it shipped to your door. It's the best as far as I am concerned and I use PB and Wd40 along with the watered down version of Liquid Wrench they sell now a days.It is pricey but ,Hey, You get what you pay for.
