I am looking for an axle for a 1963 Ford 21201.This is a basic Ford 2000 series,all purpose tractor with a Sherman Backhoe and front loader with Sherman over/under/normal tranny.
The axle is fine spline, with heat shrink collar retainer at bearing end.
This tractor was bought used,and the axle is bent,making it impossible to seal the trumpet to the housing.
I did not put the axle in a lathe and use a dial indicator,just loosening the trumpet bolts slightly , and rotating the axle shows a wobble.
When trumpet is tightened all around, it will loosen up in about a day or two.Red locktite no help,that is why I checked for bent axle.
Anyone got an old straight axle lying around?(right side axle).
Thanks in advance for all help on this matter.
