need case-o-matic pump specs
Does anyone have the critical tolerance specs for the hydraulic pump for the case-o-matic trans on a 530? I need to know the max allowable spacing between impeller gear teeth and the max spacing between the top surface of the housing and the face of the gears. I don't have a pressure gauge to test the pump and it is not installed in the tractor.
Does anyone have any ideas on how to determine pump flow/pressure on an uninstalled pump?
Jim
